Discuss Ups/ips in the Canada area at ElectriciansForums.net
Can UPS system system of APC Smart UPS 3000VA (2100 W) support two/three fans? I have that UPS for my office network system. I want to use it for home utilities when power fails. Can I do it? I tried APC websites....faild to get any such info.
UPS can come in big sizes often used to control machine control panels in countries with unstable power supplies. Ill try and remeber the name of the supplier we used? So yes you could get one to power some fans for a short while!
As far as i know ips are interuptable power supplies they turn of when mains goes. Some units can be configured to be either or, on power failure hope th.at helps
Thanks for the reply. I am in Bangladesh where power remains for short time only. I wanted to know if I can use UPS (which is primarily made for computer utilities) to run inductive loads like fans?
Reply to Ups/ips in the Canada area at ElectriciansForums.net
With next week forecast for rain, we thought we’d take a moment to explore what IP ratings are and why it is important to know their meaning. In...
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
As a trainee can I ask why the banjo is on the outside of the Wiska box. I understand that the earthing of the SWA must be maintained but would...
Hello. Millenial here who started electrical apprenticeship a bit too late, from Vancouver, Canada. I am looking to build up skills for...
Hello, I had an eicr done in 2021and it passed with four C3 items. They recommend next test date to be in 3 years instead of 5 on the certificate...
