Discuss Upside down light switch in the Australia area at ElectriciansForums.net
C
claire_r
Hey all, i have a question that has been bugging me all day as i just cant work it out!?
Changed a faulty dimmer to a light switch as it was a 500w one and I didn't have one at the time.
Put power back on.....switch was upside down......i often do this so laughed it off and moved the wires round the other way.....it was still upside down!?!
I cannot think of a reason why....or am I having a blonde moment? hehe :rolleyes:
Blonde moment maybe!!
Why not turn the switch round
Was it one of those cheap switched that have a common at the same end as L1?..poxy things caught me out one, cant remember what make it was maybe volex
If it was a one way switch, then blonde moment it was as you need to turn the switch up the other way.
If it was a two way switch and you swapped L1 for L2 then youve got me. But it's normally easier just to turn the switch round.
Everyone has days like these . . . . don't we ????
Do a simple continuity test on the disconnected switch itself - with no conductors present. Find out which terminals are disconnected and connected when the switch is the right-way up and the in the position you want it to be . . . and doing.
How many conductors were present at the switch box ?
A one-way switch is either open or closed. Swapping the wires will achieve nothing. Don't worry - I had to explain the science behind this to my boss once! He seemed to think that swapping the wires would change it and didn't believe me when I told him that it would achieve nothing.
ahhhhhh thanks all, yes it was a 2 way switch but i was only using L1 and common
changed the wires around when i should have just turned it!
ah well as I always say....in this job you learn something new everyday....even if it is something obvious hehe.
Reply to Upside down light switch in the Australia area at ElectriciansForums.net
Had to replace a Light Switch with a faulty dimmer. The New Light Switch is wired different from the old one but appears to work ok Can someone...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
