• Please checkout this (ad-free) update post I've done on a spare blog. Feel free to bookmark it and check everynow and again for update if ads are pissing you off. Always feel free to ad-block them for now though if you want. I'll let you know when you can disable the ad blocker again, only if you want to see the ads. They should look nice and neat in the end.
Discuss Upside Down UK Plug Socket - Is This Normal/Ok? in the Electrical Forum area at ElectriciansForums.net
OnlQQker
Hi all,
Just recently moved into a renovated house in the UK where a desk is quite high, so the plug socket above it has had to be put in upside down! Other than a bad case of OCD, is this normal/ok?
Please see attached photo.
Cheers,
Will
Upside Down UK Plug Socket - Is This Normal/Ok? {filename} | ElectriciansForums.net
OP
G
Grimers
Hi all, so quick update on this. I rotated the socket earlier (making sure the circuit was isolated). Some plugs fit fine (like a Lenovo tablet charger for example), but obviously some don't due to there being next to no clearance between the desk and socket (see image). For the plugs that don't fit, what is the safest way to get around this? Is it best to use a cube or something like a T plug extension? Thanks for your help!
DPG
Patron
Cube adaptors are best avoided. And I'm not a fan of the t-type ones either. Use a good quality 4 way strip type one with a lead.
littlespark
problem with that is the flex lead coming out the plug being squashed against the worktop there.
a cube adaptor for this situation, propping it up underneath so its not falling out the socket due to gravity.
DPG
Patron
Good point. I'd forgot what the original problem was!!
Yeah cube type is ok if it's supported as littlespark says. Make sure it's a fused one though.
Reply to Upside Down UK Plug Socket - Is This Normal/Ok? in the Electrical Forum area at ElectriciansForums.net
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Hi there, wondering if anyone can give me some advice please. In my kitchen I have a cooker switch with a plug socket which I believe is on a...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
Its common to read in literature and textbook, that providing we use an adequate twin earth rated cable, a UK Double socket is capable of 26Amp...
New Posts (Please Reply)
