Discuss Urgent help needed in connecting a push switch to a string of battery LEDs in the Industrial Electricians' Talk area at ElectriciansForums.net
R
Raj Memtaj 1990
Hello my name is Rajiv Memtaj I am currently working on an A2 Product Innovation project and i want to attach some LEDs to my unit which are activated using a switch but i dnt knw how
CAN ANYONE PLEASE HELP ME?
My email address is [email protected], plese contact me if you have ne suggestions on making it work.
Below is the problem
I have a simple 'push to break switch' which i bout from maplin. the picture is below.
Below is a picture of the LED lights i am using, sorry the picture is not too clear
The lights look amazing when lit up which is why im so keen to connect the switch, i want it to work so when a door is opened the lights turn on. PLEASE HELP AND TELL ME WHAT I HAVE TO DO
Heres a pic of what they look like
Thank you for viewing, i look foward to your comments and advice on how i can make this work. Thanks :D i'll be very gratefull if you can help me
If you decide to help me i can send you the pictures
Hi see what to do ,explain it all again ,because i dont know what your trying to do ,a switch is a switch ,i would just put one wire in each hole and turn on!
but then again ,im not qualified yet,so my advise might not be worth a light
good luck,,,,,,oooops
Right ,pull a wire off the battery ,any wire and connect to the switch ,any terminal will do ,then get a bit of wire and connect it to the other switch terminal and the battery where you took the wire off.
your on the right site mate,well make an electrician out of you ,a little bit of self experiment wont go amiss mind
atvbitwww
all you are doing is putting the switch in series with the lamp
Rum has told you exactly how to do it
the problem i think you have will be sperating the common supply
the lamps cables should go to two coomon points - one posistive, one negative (may be at the battery, may be on a terminal board)
remove all the cables from the posistive bit and connect to one side of the switch
from the other side of the switch, connect a new cable to the point you removed the first cables from
you will probably need a soldering iron
now, dont try and misenterprate what i said, like you did with Rum's very helpfull post
just do what i said, how i said
oh, and i now own you hahahahahahahahaha (thats an evil laugh by the way)
sorry for asking again but the other methods are not working, as another method could i simply cut one of the wires and then connect either end to the push switch? surely that will work because arent i breaking the circuit and including another circuit? please help
ok now i've bought the soldering iron im confused on what type of wire i need, im thinking of ordering form 'Maplin' they have arange of wires below is the description of what i want
the description for this is:
To DEF61-12 (Part 6) Type 2
A wire having a single solid core ideal for plate-wiring (running wires across a chassis with all wires straight or at right-angles to one another) because wire stays exactly in formed shape without ties.
When i do purchase the wire can i simply weld the tips of the wires to its connecting pieces without anything else?
Reply to Urgent help needed in connecting a push switch to a string of battery LEDs in the Industrial Electricians' Talk area at ElectriciansForums.net
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
Hi Total novi e but have wired multiple light switches previously and survived :) I've bought a nice WiFi enabled dinner switch for a new LED...
Hi All, I'm moving into telecoms and looking for some help on disconnecting battery strings. I come from a domestic background so have not got...
Hi, I need help with my catering van, I am looking to get leisure batteries for my catering van but don't know how many i need or what i need, i...
