Discuss Urgent help needed in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
K
KillerKlown
Hi, I've just done my PAT testing course and have a urgent question. I'm doing the PAT testing for my firm. In the course we kind of drifted over class 3 items as it is very rare you'll come accross them. Typically, one of the sets of scales we have at work is a class 3. I have two PAT testers, one is a Robin Smartpat 5000, and the other is a Martindale hpat 600. Neither of these have a class 3 function. What do I do about this class 3 item? Any help would be grately recieved.
A Class III appliance is designed to be supplied from a separated/safety extra-low voltage (SELV) power source. The voltage from a SELV supply is low enough that under normal conditions a person can safely come into contact with it without risk of electrical shock. The extra safety features built into Class I and Class II appliances are therefore not required. For medical devices compliance with Class III is not considered sufficient protection. Basically do a visual and that will be ok.
Thanks my man. I have a printer and a scanner that has a ac apadtor and a old stero type connection, rounded/rectangled with two holes, like the old stereos/video players use etc. How do I test them? I only have a IEC point on my testers, and my mind has gone blank!
Adaptors are available for PAT testing IEC 60320 C1/C2 non-polarised or C7/C8 polarised (female outlet/male inlet) connector combinations.
Note, a C7 adaptor will fit C1 and C8 will fit C2 so only one set of adaptor are required for either combination.
NEW PAT KIT 3 IEC ADAPTOR SET C13 TO C6 C14-C7 C14-C5 PORTABLE APPLIANCE TESTING | eBay
Thank you very much Markie for the adapter link i have just bought a set. i usually make any adapters up i need and this could save me a faf on.
Cheers KAMAG
Reply to Urgent help needed in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Had a new unvented Boiler fitted as the old one had reached the end of it's life. Electrician mentioned that it might be worth replacing my fuse...
I'm wondering if anyone has used this tool. First of all I'm an automotive electrician but my work sent me on a PAT testing course and we have a...
Hi all, ive found myself in a bit of a desperate situation here. I sat my compex 10 months ago and failed sections 01 and 04. I was meant to...
9K
