Discuss URGeNT wiring the disconnect to 3000 watt water heater in the DIY Electrical Advice area at ElectriciansForums.net
Pyro71
Hi, I'm replacing oil water heater with 3000 watt electric. square d main panel. bi pole 20 amp breaker. 12/2 wire to a eaton dp221ngb 30 amp disconnect. I have 118v on both conductors going in disconnect but no power coming out. two 15amp glass type p fuses are in the disconnect. Why is there no power on the out? fuses tested good. Thx
Tank is 240v
Reply to URGeNT wiring the disconnect to 3000 watt water heater in the DIY Electrical Advice area at ElectriciansForums.net
