Discuss USB sockets and IR testing help... in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
I have seen somewhere recently that one particular brand of USB socket is good for 500v for IR testing, but I can't now remember where or which brand. Is this now the standard for these things? Has anyone come across any brands which are ok to do this on? Help appreciated...
It should also be noted that the electronic circuitry inside the SMPS could easily be damaged by a 500 V insulation test injected across it. Consequently the USB port may fail to function following a 500 V Line to Neutral insulation test.
BG USB sockets state on them that an IR test will give a reading above 10MΩ.
I cannot remember which test i.e. 500V or 250V and I am fairly sure it was not line to neutral.
Personally, I remove the sockets and bypass with wago connectors. I don’t like it but I do like the readings! I think these damn things should have an isolator built in (operated from the front with a screwdriver) that disconnects the electronics. Where’s a good BS standard when you need one!
Reply to USB sockets and IR testing help... in the UK Electrical Forum area at ElectriciansForums.net
Hi All Has anyone come across Earth Leakage on a usb Socket the appliance being plugged in is live
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
Recently changed a CU for a friend and today when visiting one of the RFC's RCBOs tripped. It was due attention anyway as open ring and no time to...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
