Discuss USB sockets earth leakage question in the UK Electrical Forum area at ElectriciansForums.net
stuarth
I have a customer who has been providing all the accessories for their renovation a real mix of manufacturers and styles, we arrived to second fix and swap existing faceplates to find that every single socket both single and double had usb ports. My question is will these USB ports all potentially produce earth leakage regardless of wether they are carrying a load or will they only leak when being used?
Having seen quite a few teardown videos on these things I would be very surprised if they leaked anything as I can't recall seeing any that have a connection to earth.
Leakage from electronics will I believe only occur when the case is earthed and/or one part of the power supply is referenced to earth, or it contains filtering/surge management that is linked to earth.
How does the USB supply regulate voltage?
It's not necessary to have a connection to earth to regulate voltage. They are switched mode power supplies that produce a potential difference of 5v between the USB power pins... that's all that's needed for them to be useful.
That’s all well and good.
Have you examined these particular items and read the technical data sheet?
Actually before posting, I was trying to find detailed technical information about them so I could provide a response to the question that was grounded in fact.
Unfortunately detailed technical information about such matter appears to be a bit thin on the ground as I wasn't able to find anything about MK or BG USB sockets.
But I don't have to have examined them personally, like I said I've seen enough teardowns of these to know that they in general have no connection to earth (just the same as your average USB plug-in charger and even a lot of laptop chargers) therefore they are unlikely to produce earth leakage issues since they cannot introduce any kind of potential or current flow into a conductor they have no connection to. Seems to be fairly common sense to me.
My problem, is that I don’t know the make of the sockets the OP is using, don’t know how they operate, so can’t really say whether there will be earth leakage or how much it will be.
Thanks to all the responses you have answered my question, it seams there will only be a potential issue when they are in use. As to the make of sockets they vary from makes I have never heard of to LAP :eek:, they love to shop on the internet.
The customer is a absolute nightmare of not listening to any advice and changing their minds as to whats going where and constantly adding more work, more circuits etc soooo glad I insisted on hourly rate rather than fixed price, the original job was to move a few lights a couple of new spots and 6 new sockets, we have now been on site for 3 weeks in total:D
And another plus point; you will be able to make all that money twice over again when you go back to replace what they supplied...
I now actually encourage customers to source their own materials, mainly to observe the look on their face when I explain the lack of any guarantee on the material side
I love telling em there’s no guarantee on materials.....saves me a load of stress :)
I hope you knew from the outset that every single socket was going to be USB, and charged accordingly, since you’re going to have to disconnect and wago the line on them all to do a L-N I.R. test. Rather time consuming for every single socket.
No idea there would be any USB's, every time we turn up theres something more on the list, we arrived on Monday to detailed instructions on laying out the UFH complete with diagrams ffs, the customer has no idea on lighting over kill on the amount of lights per room despite advice from me and the builder and now they have started on garden lighting including RGB strobe flood lights.
Possible but would think to small to matter, good case for fitting a consumer unit with individual RCBOs
Reply to USB sockets earth leakage question in the UK Electrical Forum area at ElectriciansForums.net
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
Once again I am using the Engineering chat as I think my question is more theoretical rather than 'diy advice'. If I am misusing the forum...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
