Discuss USB sockets testing in the UK Electrical Forum area at ElectriciansForums.net
loplug
does anyone test these in any way if so what do you use. Or do you just test the 13a sockets and make an assumption that the usb skts are working ?
You can get dedicated USB testers for not a lot of money, but to be honest if you want to test a USB outlet just plug in a cheap USB light.
I have seen that they can be got cheep but I was mainly wondering what other people was using or if they even bothered to check the usb output
All you’re testing is a 5v dc supply.
If you know which pins on the plug are the power and which are the data transfer... get an old usb lead, cut it down to the individual cores and use a multimeter to verify 5v + or -
I’ve never actually checked any I’ve fitted. I assume the customer would soon say if it wasn’t working, then it’s a trip to the wholesalers.
Thanks for that and hadn’t even thought to butcher a lead what a simple solution
Better than plugging your far more expensive phone into a potentially faulty port.
That’s why I wanted to do some sort of check to avoid the scenario where a customers expensive phone gets damaged and when asked if I have tested the usb sockets having to reply no
Interesting question, USB sockets are SELV supplies so does anyone routinely measure IR to confirm isolation? 612.4.1 requires insulation resistance measurement for SELV, one to think about.
My USB socket was only outputting 2.5V after an IR test. My tenant didn't use it so I don't know what it was like before - but still I'm highly suspicious that the IR test fried it...
I quoted from the 17th but it's different in the 18th. Table 64 on page 232 specifies minimum insulation resistance of 0.5 MΩ at 250V DC. 643.3.3 recognizes that some electronics may be damaged by test voltages, and allows a limited test.
These are tests before circuits are energised so for practical purposes it may be worth chopping a USB lead, shorting all four wires together and test USB-live and USB-earth. Shorting the USB pins together should protect the electronics against damage, and if it is damaged by that it's not fit for purpose.
Reply to USB sockets testing in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I am looking for some advice re: putting new sockets and usb sockets in my home. Someone will be rewiring the entire house but I have...
Hi all, I was thinking to use heat shrink to strengthen usb cables where the cable enters the connector. I find the insulation starts to crack...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
Looking to fit a USB-C PD wall socket for charging / using a laptop - so I was hoping to find one that supported 90W or higher charging, though...
In my line of work it's very rare that I ever have to change a DB. I'm largely in maintenance; occasionally have to add new circuits etc. so in...
