Discuss Use old immersion wiring to use for Sockets? in the UK Electrical Forum area at ElectriciansForums.net
Stuart Todd
Just discovered the old wiring for the immersion heater. We have very few sockets in old victorian house. The immersion heater wiring was left in a terminal block wrapped up in masking tape!
I changed the old wylex fuses on the CU to use MCB, thankfully I switched the 16A fuse off for the immersion socket some time ago. Now I have some wiring to play with, I have a couple of questions:
1, Can I use the wire to set up some new sockets. It is likely the sockets won't be used to pull much. Although it depends on below.
2, I haven't measured the size of the cable yet, if it is 2.5mm t&e, what's the width of the cable and would I be able to switch the 16A with 32A at the CU?
3, Do I put it in a junction box and have the cables feed out from this?
Many Thanks
You may be able to use the cable for sockets, provided it is in good condition (insulation resistance tests will help determine).
If modern T&E, it is likely to be 2.5mm2, if older imperial cable it will likely be of a similar size (and rating). Assuming so, then NO, you cannot just change the 16A MCB to a 32A one, the cable might be damaged by overloading (melt) before the MCB would trip.
You might be able to use a 20A MCB, but you need to know that the disconnection times are met as well as the cable rating.
Hi dude,may i suggest that the phrase "...some wire to play with..." may provoke some spirited and curt responses. You have been tipped...:stooge_curly:
and i'd like to warn you the phrase ''you have been tipped'' might be a reference to frotteurism
I tried pulling my mates car with some cable once, snapped though
obviously you mis-calculated he cable type and size. S = (W x V)/ ( sq.rt. T ), where W is the weight of your car, V is the towing speed, and T is the time for the journey.
Reply to Use old immersion wiring to use for Sockets? in the UK Electrical Forum area at ElectriciansForums.net
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Afternoon all, I have an issue with the loft socket. When we moved the previous owners had a 2.5mm cable going up from the CU Via FCU however...
