Discuss Using 4.0mm T and E in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I
ian hall
If i have a large (or long) ring main to wire i sometimes use 4.0mm. Have one in a barn conversion to wire, only 5 sockets but total run will be around 60metres. What would use?
Ian
If the total enclosed area is less than 100M2 and there is no excessive load then i believe you can use 2.5 T&E. Some one who knows better will be along shortly though.
agree with pushrod. i think 2.5mm would be fine as long as floor area doesnt exceed 100 square metres if served by 30/32A.
You must also take into account the route of the cable.
More than likely lots of derating needed due to insulation etc so, personally i would choose 4mm.
Although its bigger, its actually easier to use as its stranded and not solid core.
Reply to Using 4.0mm T and E in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Hi, My first post so hopefully I am correct in posting it here. My question is, I am thinking of an IP rated outdoor socket for the back garden...
I have an interesting scenario that could use some feedback. I have 200A service in my home with a sub panel running to a detached garage...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
