Discuss Using a consumer unit after removing total control meter in the UK Electrical Forum area at ElectriciansForums.net
I have 2 consumer units, one normal and one for t control, I no longer have storage heaters so want to get the meter removed, can I then use the consumer unit to supply the sockets that were originaly used for storage heating, my immersion heater is also connected to this consumer unit so that is my main reason for keeping it, their is no room in the normal consumer unit to take the immersion heater connections.
It is possible to do what you want. However it is not just a case of swapping the feed to the peak supply. There are other considerations, such as RCD protection for sockets.
I would recommend getting an electrician to assess the possibilities.
Thanks for the reply, the sockets are already covered with RCDs and their is already space to connect the mains supply.
Thanks again
wunatey
Reply to Using a consumer unit after removing total control meter in the UK Electrical Forum area at ElectriciansForums.net
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
Good day readers, if any,I am an old sparky, a very old sparky. I can remember old Faraday giving us lectures Wednesday evenings at evening...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
