Discuss Using a garage CU as the main CU for flat in the Electrical Forum area at ElectriciansForums.net
Why would you put a smaller CU in? If it's got spare capacity now then that's good
C2???
Likewise the steeple/lewden main switches and rcds are if i recall correctly not pole specific. the live and neutral can go on either side if required. Plenty f options if the electrician looks.Your electrician doesn't sound very flexible, did they make that C2 comment DB of old wired type that is a very non professional statement. Crabtree Starbreaker do left side isolators.
https://www.screwflix..com/p/crabtr...w5v_NVQ2TEt_0cQopTxoCXDYQAvD_BwE&gclsrc=aw.ds
DB of old wired type - C2...
My spotty bum it is...
provided you use a suitable gland for cable entry.Also, Is drilling into a consumer unit in a area (bottom left side) )that´s not a cut out ok?
That statement makes no sense whatsoever, DB of old wired type. What earthing system have they quoted.
No, you should go back and ask for regulation numbers for all the claimed faults - at which point he should realise that he's been rumbled. He'll have fun finding one to justify that C2 - as above, there's nothing fundamentally wrong with that board, and it's even steel cased like a lot of them were before people started cutting corners with cheap plastic. No RCD is mentioned on another line, and that (apart from problem getting spares) is the only thing wrong with it.Do you think I should complain?
Reply to Using a garage CU as the main CU for flat in the Electrical Forum area at ElectriciansForums.net
