- Reaction score
- 16,845
I'm going to look at a job on Monday and I'm not sure if there's any regulations that I need to think about.
The job is to install a wall mounted TV on a chimney breast, with the sky box and bluray player installed in the fireplace.
Now obviously the fire isn't in use, and the homeowners are utilising a wasted space.
My thought was to drill straight through the brickwork into the chimney and drop the cables down the void, possibly in pvc conduit. Alternatively, cut a channel into the front of the wall.
Is there any building regs to say I cant drill through it?
I also need to find power for inside the fireplace, so the whole job might not happen if there's no socket nearby.
I could run surface trunking up the front, but that's not going to look very professional.
