J
justsouth
Do you need your own testing equipment calibrated in your own name to be able to perform eicr's or can I use any calibrated tester?
Discuss using company megger in the UK Electrical Forum area at ElectriciansForums.net
normally by producing a calibration certificate,if using company equipment they should have all the paperwork on file.If you were asked to prove the meter was calibrated how would you do this?
I was assuming he meant using a tester supplied by the company he works for while doing work on behalf of his company, in which case they normally hold the paperwork,after all when you get a company vehicle they dont give you the log book,mot and insurance certificate do they?Yea fine if it's your tester and you have had it calibrated. But not if it's a company tester. Has the company given permission?
I'm sure 99% of bosses realise there staff do private work. Its the nature of the trade.
If your boss is that tight not to let you use a tester out of work he needs his tester sticking up his --- on 500v lol
surely the main point is you know the tester is in calibration and has a certificate.
Just use it.
Just use it.
Reply to using company megger in the UK Electrical Forum area at ElectriciansForums.net
