Discuss Using Induced voltage in the DIY Electrical Advice area at ElectriciansForums.net
ukmicky
don’t worry I’m not going to do this ..
If I have a wire that is powering something like a house and lay or wrap another wire around it the wire laid beside it or wrapped around will show a voltage if connected to a test meter .
If I did it to the positive wire prior to the meter in a house I asume it would again produce a voltage in the wire laid beside it. . I assume how much of a voltage would be dependent how close they were and on what is being powered in the house at the time of the test.
Can that voltage be used.
If it can would it be theft of electricity
It doesn’t work.
On a single core, then yes, you would get some voltage, but not very much.
You need a lot of coils on the source wire, a lot of coils on the secondary, and a metal core shared between both coils. That’s how a transformer works.
The cable coming to a house is, more than likely, concentric… meaning the live is in the middle, with a neutral and earth multi stranded running outside it.
That means you can’t get to the live to coil anything around it.
It's not so much the voltage that is the problem, it's the fact that if you try and take any usable current from it, it will collapse.
With a bit of circuitry you could probably power a micropower device.
But fundamentally yes, power can be transferred by inductance or capacitance.
Reply to Using Induced voltage in the DIY Electrical Advice area at ElectriciansForums.net
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
I am replacing some of the old receptacles in a 1940s house. Armored BX cable, two conductors, cable is the ground. Mostly pretty straightforward...
I am sending power to some 5v led lights about 50ft from the transformer. I was going to use some CAT6 direct Burial cable that I kept after a...
Wired my home in Europe (obviously 220v there). My assumption is wires are wires and as long as the AMPs are covered, it can be used in north...
