Hi everyone,
Just been on a new build (one off build not cookie cutter), original sparks left some SWA for a car charger and electric gate that I have been working on, I have signed off these two new circuits.
The tails have been taken from a DNO supplied main switch, TN-CS with 100A fuse. He has used 16mm SWA cable and the run is roughly 5 or 6 meters.
Is there any justification for using 16mm instead of 25mm
Also thought the DNO don't like you using their fuse to cover any more than 3m of tails.
If it were me I would have come from the DNO main switch with 25mm meter tails into a 100A DP switched fuse, then perhaps you could use 16mm right? Or am I being pedantic, 16mm SWA's current carrying capacity is high enough so who cares?!
How would you guys do it? Cheers
