Discuss Using SY cable in a fixed installation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, got a job that’s coming up which involves putting electricity to a wagon that’s half way down a field from someone’s house. They want it so it’s like a caravan, so they can disconnect the power lead whenever they want and move the wagon around.
There’s only 2 circuits in the wagon; 4 lights on a b10 and 3 sockets on a b32.
Do you think SY cable will be acceptable if buried in conduit half way down the field to a supply ballard that are used in caravan sites? Coming from the consumer unit in house protected by RCD. They are plastic consumer units and the customer has already ordered them, so SWA isn’t ideal, and the wagon won’t be pulling much load, I’ve been told a kettle and a small TV will be the only appliances. Cheers
I wouldn't even contemplate using SY. Are you fitting these all insulated consumer units the client has already ordered.
Thought so, I’ve used it before for motor connections and mechanical protection but that’s it. Yeah they’ve got insulated consumer units, but come to think of it I could still use swa still with just an outside gland and earth ring/tag around it?
Are you fitting new all insulated consumer units in a dwelling or are they already in situ, fitted.
NO Never SWA IS BEST
They have fitted the one insulated consumer unit in the wagon, and then that’s connected to a commando socket half way up the field via a cable, which is then going to be connected to there consumer unit in there house, which is just a normal household c unit
SY is not suitable for burial, even in conduit, or for use outdoors.
I like working with SY but it's not compliant with recognised UK standards for fixed wiring so technically cannot be used.
I often find that people substitute Swa for SY because they are either too lazy to install swa and the proper glands for ‘easy ness’ or they actually believe SY has all the same properties as swa and do not understand its lack of BASEC approval mark or lack of any recognised harmonised standard.
If you need to use flexible cables, then there’s plenty to choose from.
Reply to Using SY cable in a fixed installation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, Interested in the groups interpretation of BS7671 with regards to the used of SY & YY cables. We have a commercial installation where we...
Just had three split Air Con units installed at my home, the ones with an indoor and outdoor unit. I (perhaps naively) trusted the installers...
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
