Discuss using Twin and Earth ourside and UV protection in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Wondering about T&E outside, not ideal we are told due to the UV rays overtime breaking down the outer sheath.
Saying that I come across quite a bit when house bashing that has held up well and shown good IR tests.
On a data sheet for some T&E I ordered was this little paragraph:-
"Not suitable for unprotected use outside as the outer sheath is vulnerable to attack from UV, however Alkyd paint is enough to protect it from UV."
From what I know Alkyd paints are made of certain synthetic oils and dry much like a resin overcoat.
Anybody got thoughts on this Alkyd paint idea? just never noticed this info on the paperwork before.
Be wary of putting too much faith in the IR test, a cable with perished insulation could test out fine but then have all the insulation fall off with the slightest movement.
Probably the best option would be to use the correct type of cable in the first place, nothing like bolting the stable door after the Horse has bolted, cheap is not always the best, and the best is not always the cheapest.
Bit like the old Rubber cable, OK when left alone at least IR wise, start messing with it is when the heartache begins.
Reply to using Twin and Earth ourside and UV protection in the UK Electrical Forum area at ElectriciansForums.net
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
Correctly closing off a dead twin and earth cable in a loft. My old house used to have radial circuits serving night storage heaters. Those...
Hi, The current carrying capacity tables in the BS 7671 for twin and earth cables are only for buildings that have thermal insulation. I'm...
4K
Good afternoon, I purchased a 25mtr coil of PRYSMIAN 6242Y 2022 GREY 2.5MM² TWIN & EARTH CABLE in Screwfix at the start of July and found while...
  • Locked
5K
