Discuss Utility room extractor fans in the UK Electrical Forum area at ElectriciansForums.net
Apologies if this has been discussed before, for background I am first fixing a new extension with the electrician happy to check and test when I have finished ( I have previously completed a domestic installers course), according to building regs, a utility room needs an intermittent extraction rate of 30 l/s, I am struggling to find a 100mm ceiling mounted extractor fan with this capability, however, if you look at Part F of the building regs in table 5.1a extract rates there is a note which states "total extract rates should be at least the whole dwelling ventilation rates given in table 5.1b", in our case this would be 3 bedrooms and therefore 21 l/s so which rate do I go for??
Thanks for any replies
Why does it have to be a 100mm outlet fan ? or is this is what has been fitted if so you will probably be a centrifugal fan.
Why a ceiling fan? Icon 30 through the wall and you could add the humidstat option. You get what you pay for. Are bco involved?
Thanks for the replies, BCO are involved in as much as the electrician has to satisfy them that the regs have been followed, unfortunately an external wall mounted extract is not an option due to location of new LPG boiler flue and the layout of the room. I wanted to use 100mm as I have previously installed the ducting in the roof void and it would be a nightmare to try and get it out and put in bigger ducting.
Regards down2earth
Regards down2earth
could perhaps fit a 6" fan with a ducting adaptor/reducer 6" to 4".
30l/sec is for new dwellings, for extensions a 100mm dia fan of 8L/sec 0r 15L/sec (no opening window, 15 mins overrun is the BC requirement.
The op is talking about a utility room. Out of interest where does the over run timer bit come into this?
Yes I know it's about a utility room, the regs are different though for extensions and new dwellings. The overrun is for rooms that do not have an opening window, but probably just shower rooms not utility rooms, the key is to either refer to plans which have been signed off by building control, or get agreement on site from the BCI.
Reply to Utility room extractor fans in the UK Electrical Forum area at ElectriciansForums.net
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Hi all, I'm looking for recommendations for a kitchen extractor fan i.e. rate of 60l/s. We're almost finished renovating and we've just been...
Not specifically electrical, but best way to minimise condensation in a shower room. Asking for a customer. Background. Customer is a neighbour...
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
Hello everyone, I hope nobody minds that my first post is a question. We have a bit of a situation brewing at home with regards to our new...
4K
