Discuss Value of a resistor? in the Industrial Electricians' Talk area at ElectriciansForums.net
G
gm_bowen
Two resistors, when connected in parallel have an equivalent resistance of 15 ohms. If one of the resistors is 60 ohms what is the value of the other?
Question from 2330.
Can't apply 1/Rt = 1/R1 + 1/R2 + 1/R3
Was suggested use product over sum method, but not been able to calculate it?
Help appreciated.
20 ohms
product over sum:
total res = product/sum
15 = 60 times R divided by 60 plus R
therefore
15 times (60 plus R) = 60 times R
therefore
900 plus 15 times R = 60 times R
therefore
900 = 45 times R
therefore R = 900 divided by 45 (equals 20 Ohms)
Easy
Randyrat
Reply to Value of a resistor? in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi All, Just looking for some advice: I'm in the process of updating an old cable calc spreadsheet that helps to spit out Zs and Voltage Drop...
Hi, I am just wondering if you can please help me. I have four LEDs connected to a 9 volt battery. They have little circuit boards in them. They...
Hi, Hope someone could help with below situation or recommend a good forum to ask about or find information on as I read a lot on the forums and...
4K
Hi All, I am currently learning about AC and DC supplied coil and have been given the scenario below. I understand the first few steps but then...
Hi everyone, I'm new here and was wondering if someone could help to get my college project calculations right. I'm about to start my 2nd year in...
7K
