M
Matt85
Hi, having problems with my van,it's turning over but not starting (intermittently).
been to my local garage and they changed the fuel filter but no joy, so I've taken it to, two diesel "specialists" and they can't seem to find the fault. The first diesel specialist came up with fault codes saying EGR valve,engine temp sensor and fuel temp sensor, so the fuel temp sensor and the engine tempt sensor have been replaced but the van still display those fault codes. So they advised me to get an auto electrician to have a look at it as they thing it may be a fault between the wiring of both sensors. I called 5x local auto sparks and non of them are wiling to look at the van as they say it needs to go to a diesel specialist. So onto the second specialist, they come up with the same fault codes but diagnosed a faulty starter motor that is causing battery voltage to drop causing van not to start, so I had the starter motor replaced and still no joy. It's also had a new battery. I hope someone can shed some light as I'm loosing faith fast. Regards Matt.
