Discuss Veritas Alarm System Help (Remove Personal Alarm) in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
R
reddragon105
I've recently moved into a new house with a Veritas R8 alarm system fitted. In one of the bedrooms, there's a wire coming out from one of the walls with a small (the size of a matchbox) white plastic box with a key sticking out of it and a big red button which I'm guessing is some sort of bedside personal/panic alarm used by the previous (presumably elderly!) owner.
I'd like to remove this, as we're redecorating the bedroom, but I'm not sure how to (pretty sure just cutting the wire would set the alarm off - at least it should if the system is worth anything!). Can anyone offer any advice on reprogramming the system so that I can physically remove the wire?
Hopefully you have the user code.....remove cover on main control panel, when alarm goes off, enter user code to silence... disconnect cables going to pa terminal, and replace a small piece of wire across the the pa terminals. Check the are no other cables in the multi core going to other terminals 24hr etc.
Replace cover, and reset. PA button is now isolated and can now be removed
what he said^^^^^. an alternative would be to remove the panic button cover, use code to silence alarm, then diss. the 2 wires from the reed switch, twist together and refit onto 1 terminal of the reed. then reset panel. this would save going into the control panel and leave the PA circuit intact for possible future use.
Great, thanks! Yes, I have the user code from previous owner (and I know that it's correct because I had to use it when I set off the alarm by pressing the big red button on the PA because I didn't know what it was!).
So my only question now is how do I know which cables are going to the PA terminal? Are they marked? I'm just not sure which zone the PA is in but I suppose I could figure that out. And do I need to cut the power to the main control panel and if so how do I do that?
the veritas has programmable zones. to find out which zone the PA is on, press the PA and silence the panel. it should then indicate which zone has activated.
Great, thanks! I set it off today and found out that it's zone 7. Well, by set off, I mean I pushed the big red button and nothing happened. Tried several more times and still nothing. Then, later, as I was moving stuff around, I knocked it gently and it went off! Must have a loose connection. Tomorrow I'm going to go into the main control panel to disable it. Will I be okay just removing the panel or do I have to remove the fuse/power first?
take cover off panel. enter code. don't worry about power being on, apart from the incvoming mains feeed to the transformer, it's all no more than 12V. take the 2 wires out from zone 7, replace with a shorht link, refit lid and enter code followed by rest.
Reply to Veritas Alarm System Help (Remove Personal Alarm) in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, new to this forum, but t thought I'd join up, hoping for some assistance. I've just installed a Texecom prem 48. All with EOL wiring...
5K
A
Hi all, New to the forum, looking for some advice please. We have sold our house and going to be moving out soon so we are currently putting any...
A
Hi all, I've just replaced the keypad on a veritas r8 pre-2000 system as the old keypad had few worn buttons which weren't working correctly. The...
Specialist
Hi guys, I've got an alarm panel at a job I'm doing, not sure what it is as don't really do much alarm work, I've attached pics though. I have a...
Looking for some advice on what I've discovered is the electrics situation in my rental property. I'll note that before I moved in here I made...
11K
