Hello
I'm wondering if someone can shed any light on a peculiar RCD tripping problem please. It's feeding four socket rings along with garage and the PV system is also connected through it. What happens is the RCD sometimes trips between 09.00 and 09.30 in the morning and only in winter. A clamp meter on the L and N on the supply side shows 21mA leakage which is cumulative from the four socket rings. The property has gas CH and hot water underfloor heating so no electric heating. Lighting circuits are not fed through the RCD.
Any suggestions are gratefully appreciated! Many thanks
