- Reaction score
- 706
Hi all,
Been asked to quote for replacing 150 8' fluorescents on light line trunking, the fittings are on for 18 hours a day and access to many is difficult, many of the fittings are original 1967 cromptons still going strong! have been looking at replacement options, just wanted opinions of the forum.
So far the options are...
Thorn twin 6' t8 high frequency fittings circa £26
Crompack LED fittings (5' equivalent)circa £106 each
T5 flurries (haven't priced yet)
So far, I can't see much advantage in the LED fittings, they output lower amounts of lumens per fitting and still only manage 96lm/w. Compared to a 70w t8 at 89lm/w.
Another consideration is the distance between the lines of lighting trunking, flurries give a good spread whereas Led's tend to be a bit more localised.
Also lifespan is an issue as I don't want to be on repeated call backs for faulty fittings and I'm not 100% convinced by LED lifespans yet.
Final point is price, convincing someone to buy fittings at more then four times the cost may be an issue!
Any input much appreciated
