Discuss Volt Drop in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
Phaze-3
Hi guys,
Need to put a 32A 3phase supply in to a 10KVA site transformer using swa. The run is 250m long but would i need to apply 3% or 5% volt drop??
It works out at 3% i need to use a 35mm cable and at 5% i can use 16mm.
Anyone have any idea???
Phaze-3
Reply to Volt Drop in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I'm looking for a bit of advice on a volt drop query we have in our office. I'll explain the scenario and I would really appreciate any...
Hi, thanks for reading this. Ive been asked to look at a job where the DNO connection (single phase 80A TT) is a long run to the final circuits...
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
I am trying to understand 3 phase volt drop. I understand single phase VD. Lets say we have a 70 meter run of 35mm, 5 core cable from the supply...
Hi guys. I was a commissiong technician before I retired. Hardware and software industrial automation. Miss the work but not the endless travel/...
