I've finished rewiring the upstairs in our house (in Bulgaria). This is 3 bedrooms and the living room on separate ring mains. I bought an earth rod and put that in the yard and as I was connecting up the earths, I decided to check if there were any voltages between various points.
With the earths not connected to the board, there is voltage between live and earth but not neutral and earth.
Needless to say, I went and checked everything that I could.
There is no continuity anywhere between live and earth or neutral and earth. I took out each outlet and inspected and nothing is wrong. I also tested voltage between live and the earth rod and it's the full 220v. The earth rod just has a cable from it to the board.
Is this right, do I just connect up the earths to the rod?
