Discuss Voltage Regulator keeps tripping in the UK Electrical Forum area at ElectriciansForums.net
I have installed a 16 amp variable voltage regulator to control the voltage for a DC generator running at 6 amps, each time when I switched on the regulator, it trips both the breakers at the generator unit 32a) and also the house breaker and blows the fuse in the plug. If I disconnect the regulator and hard wire it from mains to the bridge rectifier (35a), everything works fine. Did I used the wrong voltage regulator or do I need something else like a speed controller etc ?
What Voltage is the Genset dishing out? and does the output from the Genset correlate with stabiliser?
I don't think it's a genset Pete, generator may be a misnomer.
OP - please can you give more specific info and/or schematic. What type of voltage regulator and what exactly do you mean by 'DC generator'. I'm guessing you have connected a phase-angle controller upstream of a linear power supply, which won't work correctly.
In your earlier post you provided a picture of the HHO machine you have constructed. This is the circuit diagram for it.
I in this post I repeat that what you have constructed is unsafe- both as a piece of electrical equipment and a producer of flammable hydrogen and oxidising oxygen gases.
All you stated was telling me unsafe as this does not help me further, no explanation whatsoever ? I was just needing some advice from members to point me in the right direction and some members were very helpful
Think you are overreacting Michael, when someone of Marconi's undoubted knowledge in things like this, you could do no better than listen to his advice.
Instead of whinging about the fact that it has been pointed out that your setup is inherently dangerous, why not ask why it's dangerous, you may get some sound advice.
Unless built and tested to strict constructional standards, the use of non-isolated mains supplies in an electrolytic cell poses a risk of electric shock from any part of the system in liquid contact with the cell. Especially as any upstream RCD protection may be defeated by the rectifier, unless the RCD is DC-sensitive. I cannot say why this particular phase-angle controller doesn't like the otherwise fairly resistive load, but you are using it outside its design envelope so anything might happen.
I am at sea so only occasionally able to access the ef. Lucien points out the danger of electric shock. There are no interlocks to turn off the power when the access door is open and the hho cell is an exposed and energised metal structure. I see no attempt to shield it from being touched or insulate the cell from its surrounding metalwork so what happens if it leaks. The circuit has no functionality to stop gas production when it is not being burned. It has the bare minimum of flash back protection - the bubbler - and there is no sensor to detect the bubbler has the required volume of fluid in it. H2 is a lighter than air gas which will accumulate in the top layer of air in a room if not vented away. H2 burns very well and is easily ignited by low energy sparks. Depending on the stoiochemistry it will either burn, deflagrate (very rapid burning) or if just right and well mixed with air detonate - in both cases with great explosive force and deafening sound. I could go but think hydrogen production is best left to experts and used in legally controlled environment. How well insured are you?
Reply to Voltage Regulator keeps tripping in the UK Electrical Forum area at ElectriciansForums.net
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
