richardg
- Reaction score
- 17
Some help and guidance needed for a property I was called to inspect. After inspecting a domestic property and being paid to rectify all the faults I have been stumped with the problem of recurrent lamp failures!
The house has a history of regularly blowing all types and makes of lamps- as part of the works I installed new LED downlighters from TLC. These baby's have now all blown as well. There were no loose connections and the circuits are good.
I'm thinking something else is to blame.
Can you recommend any equipment which can be used to monitor and record the current voltage and harmonics in the property?
This may lead to a voltage optimiser if the culprit is the incoming supply.
Regards
RichardG
Regards
RichardG
