Discuss Vynckier RCBO in the UK Electrical Forum area at ElectriciansForums.net
A quick google search for me gave at least 2 sites where you can purchase these from. So I am sure you will get the same results if you try it.
So try ringing your local wholesalers tomorrow. They will then be able to tell you if they have any in srtock, or do you expect them to on here 24/7 just incase you require a part on a day they are not open?
Nah i havent, there has never been more than one other person everytime i have been there. Theres another one in byfleet too, i use them when im in the area which isnt too often
Reply to Vynckier RCBO in the UK Electrical Forum area at ElectriciansForums.net
Afternoon, I need to change a memera 2000 6amp mcb for an rcbo that is compatible . I believe the mentioned mcb are not made anymore. Anyone got...
Folks. I need to install a defib unit outside on a wall. Does this require an RCBO or not, just wondering as the unit has a small heater within...
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
I’m probably going to look stupid here, but it will be worth it if I get the answer 😆, as I can’t fathom it out. I’ve never really thought of it...
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
