Discuss WAGO screwdriverzzzzzzzzzzzzzzzzzzzzzzzzz in the UK Electrical Forum area at ElectriciansForums.net
Pete999
Anyone got one of these jobbies?
its clearly for unscrewing bent screws, if you use this they are then in effect straight so maybe come out easier?
I was once sat in a beer garden and was observing a little insect crawling across the table. As it did so it meandered more than the Mississippi....left right left right... But then it went through a small beer spillage and when it came out the other side it went in a perfect straight line for a good six inches! P15sed, I dunno!!
Reply to WAGO screwdriverzzzzzzzzzzzzzzzzzzzzzzzzz in the UK Electrical Forum area at ElectriciansForums.net
Hi All, As a householder I'm keen to add a double socket further along a wall to extend access in a different corner of the room. I'm connecting...
Been using Wagos since they came out, love them, but was wondering do you use them in poured resin submarine joints. Obviously if the resin had...
Hi, I need to swap out a damaged 30A junction box on an existing ring main circuit and thought I'd replace it with Wago 221 connectors and a Wago...
Wondering if there is a maintenance free wago for extending 10mm cables? Tried searching and couldn’t find anything. I prefer a wago to a through...
5K
Hi there can you leave a wago connection joint in a wall to plastered over Evan if your using the wago connector box that wagos go on but then iam...
