Discuss Wagos in trunking in the UK Electrical Forum area at ElectriciansForums.net
Would it be against regulations to put wagos into some maxi trunking to extend cables for a board change?
Needs to be accessible Josh. and if you are stuffing Wagos in trunking it can't be accessible without removing the trunking lid, better to bring it out into a suitable enclosure marked up effectively. All very well knowing there is a joint, but where exactly???? sorry to disappoint others but that's my take, could be searching for hours otherwise, come on guys get real.
Surface mounted cables come from under the stairs about 200mm and stright into the old board so wanted to have it that i could pushed into the void if that makes sense and do the joints in the trunking. Look rough if i just had 8 JBs in a cupboard?
Sorry Pete... your post wasn't up when I started typing mine... I'll get me coat..
No need Mate
[automerge]1568305333[/automerge]
Can’t think of anything wrong with that regs wise.
I think it would be better to take the existing cables into an enclosure (j/b) and connected extensions from there.
Like I said Pete
But an adaptable enclosure with strain relief and connections inside would look neat.
EDIT: Chris beat me to it ? :handpointup:
Are talking about one or two wagos to extend one or two short cables , or extending many cables by stuffing a load of wagos inside the trunking ?
If its one or two then imo its not so bad and a quick solution to a small problem
If its multiple then no , I would opt for a lidded box and put all my connections inside that
Is 412.2.2.3 relevant in this case? My thinking is the trunking lid can be removed without a tool and the Wago connector is not IP rated.
Not sure on the exact IP rating for Wagos but if used correctly you should have no exposed copper wire or live parts to touch. They are fully sealed unit.
Surely it's no different to extending a T&E inside a consumer unit using some wagos, etc. where it's a bit short. And the joint is accessible by just popping the trunking lid off, which is no more difficult than opening an MF enclosure.
what's wrong with twisting and taping them? obviously needs 2 wraps (of tape, not heroin) to make the joint MF. :smilingimp::smilingimp::smilingimp:
Why not just a large enough adaptable box with wago din push in things? Trunking either side of it if theres space?
aDon't you guys read the//
Because if you know the joint is in the CU then, not far to look for it, however in trunking where do you start looking?
Reply to Wagos in trunking in the UK Electrical Forum area at ElectriciansForums.net
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi, I am currently doing a level 2 (2365). We have been doing trunking factors and I am not sure about if you need to apply the 45% space...
Hi All, As a householder I'm keen to add a double socket further along a wall to extend access in a different corner of the room. I'm connecting...
Hi all. I am installing some metal trunking vertically in a meter cupboard to contain all the meter tails for an apartment block. I have 5 sets...
Wondering if there is a maintenance free wago for extending 10mm cables? Tried searching and couldn’t find anything. I prefer a wago to a through...
4K
