Discuss Wagossssssssssssssss in the UK Electrical Forum area at ElectriciansForums.net
ChrisElectrical88
Mentor
What type of maintenance free push in connectors does everyone buy. I go through these like im eating them, use them for everything and love them.
I will never use anpther brand apart from Wago on the slimline lever reuseable connectors which are rated at 32A and perfect in every way.
However on the push in single use ones does everyone use wago? Ive been looking at the Ideal ones which are rated at 32A as opposed to the 24A the wagos are rated at. Ive been using the new slimline Wagos recently but there 30 percent more expensive than the Ideals. I believe the manufacturer SWA also do a similar product, anyone have any experiance with them?
Looking to buy ma few hubdred of each of the 2 pole, 3 pole and 4 poles connectors but thought id get some other opinions before buying a years worth.
Wagos always for me just cos I like they MF boxes, you can reuse the push ins Chris if you pull and twist back and forth at the same time they will come off easily...
I use alot of the Grey Wago Joint Boxes if there what your talking about? Excellent for making safe between first and second fix etc just snapping over the wagos. However the Ideals also fit in these.
Ideal and Wago's are both rated at 32A when not used in maintenance free mode. For maintenance free installation you have to down rate them both (to 24A)
And these connectors are only ever maintenance free when installed in compliance with the maintenance free instructions supplied with the connector boxes (Wagobox, Wagobox XL and Wagobox XLA for Wagos and the In-Sure box for the Ideal connectors). Using them in any other way means they are not installed in MF mode and must be accessible for inspection.
My personal preference is Wagos because of the availability of the various Wagoboxes.
Evening,
Where is the best place to get them from. I expect you to say the wholesalers, but you’ll all no doubt probably have other sources.
If you don’t use many then TLC will sell em in about 20 packs I think most places it’s bixes of 100’s....if you don’t use wholesalers then screw-fix have a good range of em..
Much appreciated to all.
I’ll have a delve and try to reach into my deep pockets to get a big set.
Reply to Wagossssssssssssssss in the UK Electrical Forum area at ElectriciansForums.net
Hello Can anyone confirm for me what the following spec for a Wago TopJob 2202-1201 din rail connector means? The connector can accept max 4mm...
I found these today so ordered some as I suspect I will need to extend a few cables when doing some work soon...
  • Locked
5K
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
