G
GaryM
Has anybody updated the firmware on a Fronius IG TL inverter via USB?
I've read a Fronius PDF guide that states if the software version of the 'Display Software' is lower than SW V1.1.1.0 and the software version of the 'Power Stage Software' is lower than SW V1.1.0.0 then an update is recommended.
I have an update file which I downloaded from Fronius just in case but after popping into the garage to check the software version numbers I found that the inverter is asleep with nothing at all on the display.
How do you wake them so I can enter the setup menu to check?
