Discuss Wall Chasing...... in the Electrical Tools and Products area at ElectriciansForums.net
M
MacSparky
I would like some opinions on the wall chasers that people own as i am looking to purchase one in the next few days.....'or' if you guys/gals chase via other methods then i would love to know what you personally prefer.
Regards
MacSparky
I use a Bosch 110v Multidrill with chasing bit in it. Awesome bit of kit that doesn;t quite kick up as much dust as these 'purpose built' chasers.
Chasing walls?
but wont you get, like, dirty and stuff doing that?:eek::eek:
and 110V kit? i remember the good old days of the 16th edition when 110V kit was in the regs. Long gone now of course, but thats progress for you.:rolleyes:
Chasing walls?
Tony
Most sites now won't let you use your mains powered tools unless they are 110v and PAT Tested.:p
read the 17th edition chaps, all of the different voltages for construction sites have now gone
the new section is construction and demolition sites, and basically its just 230V kit with an RCD!!!!
loads of changes in there, all of the mixed disconnection times, 25V touch voltage etc.
All gone
i'm not saying you CANT use 110V any more, i am saying under the 17th it is no longer a REQUIREMENT
like i said this has been driven by the manufacturers
in a few years time your apprentice will be saying, so whats this yellow plug used for then?????
One of these:
Armeg SDS Plus Channelling Chisel 30mm - NoLinkingToThis, Where the Trade Buys
In one of these:
Bosch SDS Hammer Drill GBH36V-LI 36V - NoLinkingToThis, Where the Trade Buys
Forget those stupid chaser things. More dust than necessary and still gotta chisel the stuff out anyway most of the time.
One of these:
In one of these:
Drill sure looks good and im a fan of the blue bosch range also, but that chisel is only good in brick and stone if a channel has already been cut, you'd kill it pretty quick otherwise, would be fine in block.
I went out yesterday and bought this Sparky FK 652 230mm Wall Chaser 110V - NoLinkingToThis, Where the Trade Buys
I'm using it monday and ill will let you know what i think, not a bad price for the specs (channel width/depth )etc....compared to others at whopping prices...lol:eek:
Regards
MacSparky:)
Sorry MacSparky,
Shoul've linked o some general SDS bits too. I generally also drill a series of holes along the line of the chase with an 8mm bit, depending on how neat the chase needs to be and how hard the bricks are. Having said that, the armeg has lasted a good while and I do sometimes use it without pre-drilling.
Re the drill - yes, it is fantastic. Had a Dewalt 24v NiCad beforehand and thought that was good. However, I could kill three batteries in under ten minutes towards the end. When it was dropped in a bucket of plaster it was time to replace. The Bosch is superb and the batteries last much longer and provide much more power.
Tempted to use the chasers myself but the first and last time I did I nearly died - couldn't see the end of my nose for dust!
Lol....i like the drilling holes technique...thats a new one to me..many thanks:D
Regards
MacSparky
Really! Only takes a couple of minutes and does help if the substrate is hard. Like I say, don't bother on softer substrates but worth the extra time on harder ones.
we use a purpose bosch chasing maching with a henry vac attached, then the armeg 30mm chisel.
looks good im fancying one of those. have you seen the sparky chisel only with 6j of energy. that should tackle red brick.
Regards
MacSparky:)
well how did it cope.
Sorry guys forgot to come back to you on that one....lol
Yes very pleased. so far chased to 25 & 35 mm depth x 9 channels and it did them in one pass.......blades are still surprisingly left like new and the channels were both red brick and concrete block, oh yeah it makes a 'cool' sound when its winding down ....lol
Downside is its quite a beast and not as light as others.
Overall for the price and good specs compared to other main brands that are more pricey i think its a bloody good bit of kit, but then its early days yet.....lol:D
Regards
MacSparky:)
Looks interesting, been using a bosch one but it doesn't go wide enough really, depth is a bit suspect too!! Was thinking of a hilti one but they are really expensive, £350. Would appreciate a report on how well it performs!! Ta
Reply to Wall Chasing...... in the Electrical Tools and Products area at ElectriciansForums.net
Maybe I've just been lucky, but I very rarely have an issue with customers paying, the vast majority have paid straight away or within a few days...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
Hi guys. It would be really useful to run this past you and get a consensus/input from you for what would be a realistic amount to charge for an...
