Discuss Wall light situation........ in the UK Electrical Forum area at ElectriciansForums.net
Hello
I have got a job - to put another wall light between two existing wall lights. as seen on the diagram attached, i have two routes. Route 1 - to simply chase horizontally along the wall to the situation of the new wall light, or route 2 - create a junction box in the cieling and run a vertical chase down the wall. doing route 2 would involve pulling up carpets etc so not as practical.
which route is better - 1 or 2?
Can't see any drawing, Barnaby?
I think the best method here is your route 2.
Lift the carpet, lift a floor board, connect the new wall light cable to the existing wall light cable via a junction box.
Chop the new wall light cable vertically down to the new wall light position.
EDIT...sorry Pete, your suggestion may also be viable, it is just not how I would go about it.
Route 2 means less disruption to the wall and only leaves one cable to connect into a small wall light. It also prevents the possibility of someone drilling the cable whilst putting up a picture of little Jonny. Chopping cables horizontally is permitted but leaves the chance of them being drilled I think?
Other peoples thoughts are welcomed.
Reply to Wall light situation........ in the UK Electrical Forum area at ElectriciansForums.net
I have an inground pool with a 22 year old, 120vac light fixture in a niche connected to water-holding conduit running to a switch in an...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
