Discuss Wall Mounted TV cable questions in the Home Media Centre Forum area at ElectriciansForums.net
A
Andrew Monks
I'm planning on mounting my 42" LCD TV to my chimney brest. I want to run all the cables in the chimney brest out of sight. There would be 3 HDMI cables, a power cable and an aerial cable. I've seen an american product called wiremold which would be perfrct but it isn't available in the UK so I'm looking for other solutions.
1. Can I safely run the power cable in the chimney brest into a surge protector socket?
2. The chimney is made of brick, what's the easiest way to drill into it?
3. are there any other options?
Remembering I'm in the UK so can only use UK products
1. Can I safely run the power cable in the chimney brest into a surge protector socket? as long as the cable is secured and not liable to be damaged.
2. The chimney is made of brick, what's the easiest way to drill into it? SDS drill and masonry bit.
3. are there any other options? ​keep 230V cable and signal cables apart. get a local electrician to do it.
Can I run the power cable supplied with the TV through the chimney? It's long enough
As long as there is no fire in use
Reply to Wall Mounted TV cable questions in the Home Media Centre Forum area at ElectriciansForums.net
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
Hi all, Have a relatively simple question. Doing a rewire to make a circuit in a single room. My father is a retired spark, so no worries about a...
For emergency use, when there's a power outage, the current situation (no pun intended) is that I'm running a hook up cable from the 16A socket on...
I am looking for advice on getting an upgraded 25 meter extension cable from my office into my car park to charge my EV from an IP66 rated socket...
