Next week I'm starting to build a few built-in wardrobes for the bedrooms and I've hit a brick wall on the lightning element.
Normally I run 1.5mm 2-core from a junction box to the different LED strip light locations, and then from the junction box to the LED driver and from there to a (switched) supply.
I would prefer to stick to generic parts so that if anything fails down the line, its a simpler replacement. However when it comes to these cabinet/door sensors, every single one seems to demand get the whole kit due to proprietary connectors, i.e. you need their wires from driver to LED tape, in many cases you need their tape, their driver etc.
examples below
I appreciate that technically I could cut off their connectors once I've got past the door sensor part of the equation but do any manufacturers make the kit so that off the shelf it allows you to just use your standard setup?
examples below
Door Sensor With Twin Heads DSIR-DUO-TOP
Modern looking door sensor with infra-red sensing detection capabilities. Twin head version which is suitable for use with two cupboard doors. Single head version also available. Simply position the sensor inside the cupboard and wire it to an LED driver. It will then automatically switch on...
www.downlightsdirect.co.uk
Syndeo Plug and Play Short Range Infrared Cabinet/Door Sensor
Shop our wide selection of energy efficient LED lights and lighting accessories here at Ultra LEDs. Get free UK delivery when you spend over £75. Buy now.
www.ultraleds.co.uk
