Discuss Water heater in the Electrical Forum area at ElectriciansForums.net
G
gary272
Hi
Been contacted by a church nearby. Wiring is pvc single stranded cables in steel conduit some 30/40years old with a few additions. It looks in reasonable order or as far as I can see. Protective devices are porcelain rewirable fuses.
They have asked me if I can wire a small water heater in the toilet. They realise that the distribution equipment wants replacing but there is to be an extension built within the next couple of years and would rather wait if at all possible. So, here goes; there is an existing socket on a ring at the rear that I could spur from through an rcd type fused spur, wiring would be surface/mini trunking. So we would end up with the water heater through an rcd, protected by a 1361 fuse. Is this acceptable please guys??
1st post so please go easy! and thanks.
well, if someone can point to a reg. that says an RCD needs fitting, then i'll buy TC a tuna sandwich. OH< Sod it! a whole tuna.
house of God. does that qualify as domestic or commercial? you answered your own question there lol
does God actually live in there? I believe he has holiday homes in florida and France as well
does God actually exist? Dont even go there ! :)
if so, how do you give Him the certificate? Stuffed inside a bible
The Friday nite madness hour has begun. ;-D
anyway, holy water contains it;s own protection. ask my polish aunt. her version of holy water is 100deg. proof polish vodka.
looks like TC's on bread and water tonight.
I may be mistaken but Is there a section in the BGB about buildings of architectural importance requiring a 300 ma RCD
Dont have my book with me but I am sure someone will correct me if not.
if the manu. inst. say fit RCD then you have to fit one. try asking the silly buggers why, though, and you won't get as sensible answer.
A lot of water heater installation instructions say they must be protected by RCD. Compromise - put in an RCD FCU :)
I think you should follow the manufacturers installation instructions, as far as RCDs are concerned.
If the heater is rated 2.0KW or over, then I don't think you are allowed to tap off the Ring circuit.
You will then need to run a new circuit for the heater.
probably the same power that insists on pyro. must be deferring their options in case of going to hell.
Reply to Water heater in the Electrical Forum area at ElectriciansForums.net
