Discuss watts and VA in the Canada area at ElectriciansForums.net
In a simplistic view, then yes.
If you want the more technical answer, the VA is purely a product of the Voltage produced by the supply and the current drawn from the supply.
Watts is a product of the voltage dropped accross the resistive element of the load and the current drawn from the supply.
Volts Amps Reactive (VAR) is a product of the voltage dropped accross the reactive elements of the load and the current drawn from the supply.
the difference between these values is the Power Factor (ie Watts / VA)
With a power factor of 1, with a purely resistive load (although in practice all loads have some reactive elements) then Watts would equal VA. A generator rated at 10KVa would supply 8Kw at a power factor of 0.8., and 10Kw at unity power factor
VA is quite often refered to as "apparent power", Watts are "true power" and VAR is "reactive power"
All off the top of my head, but I hope this helps!
Reply to watts and VA in the Canada area at ElectriciansForums.net
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
I have a lighting circuit cable (1mm) powering a telescope (12 volts) in an observatory total draw 84 watts drawn from a transformer. There is a 6...
I am lighting my workshop with LED's. I had all 13W (1500 lumens) but wanted more light on the benches, so ordered some 23W, which is supposed to...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
I have 3 pendant light fixtures with a total of 540 watts of incandescent bulbs connected to a GE electronic dimmer. The bulbs flutter from bright...
