Discuss Ways For Water Tank Level Indicator in the UK Electrical Forum area at ElectriciansForums.net
@spinlondon It will be too crude.I found these View attachment 49480
that can work that way but still to much mechanical movement involved.
Like @Rob said above a good solution is a pressure sensor transducer.It seems the most logical. I found this, View attachment 49481 which is not cost prohibitive.
I found a second solution like you say but it works with the resistance of the water.View attachment 49482 and is just 40pounds.
Crude = less to go wrong
The first ones you show, require drilling into the tank.
If you want to go crude and drill into the tank, attach a clear plastic tube on the side of the tank, with an orange ping pong ball inside the tube.
I've got the cheapest,easiest way round this,with 60 meters of clear tube,and a barbed tank fitting....how level is your site? ;)
Reply to Ways For Water Tank Level Indicator in the UK Electrical Forum area at ElectriciansForums.net
Good day readers, if any,I am an old sparky, a very old sparky. I can remember old Faraday giving us lectures Wednesday evenings at evening...
Hello all. I'm just looking for a bit of advice regarding our meter. EDF keep badgering us to have a smart meter fitted, and they recently...
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
Hi, I've got both a solar pv and an ashp system. The solar system also has 2 batteries and it's configured to fill the batteries first and then...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
