Discuss Website update of FIT rates in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
F
flyman
Is there any requirement within the code of practice to have the current FIT rates rather than the old 41.3p rate? Seems there are some websites that still list the old rate giving an unrealistic comparison.
Now the new rate is "agreed" I would most bona fide companies would expect webpages to provide accurate information to potential customers.
This comes under "advertising standard agency" you cannot advertise something that is not available as part of the reason to buy, they will be given time to change their advertising, but if you wanted to speed the process up there are many ways to do this.
tbh, I reckon that there's been enough press around this that any company still having the old FIT rate on the website is only going to be causing themselves to lose customers, as the customers will know the site hasn't been updated etc. and see this as not being a good sign.
Reply to Website update of FIT rates in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I've just stumbled across the below elsewhere online, anyone aware of it? PRESS RELEASE: ELECTRICIAN’S GUILTY PLEA OVER REPORT SIGNING OFF...
6K
My customer read on many forums about people suffering to solve a problem with the above Land Rover with regards to a fault code known as P1260...
29K
Right, a few years back when I moved in with my partner, we had many problems with the oil boiler & central heating system which my partner had...
Solar PV still attractive tomorrow!STA explains value of solar investment to domestic consumers New calculations show that investing in solar...
4K
A
Today the government proposed a cut to the FIT rate of over 50% on installations lower than 4kW. The current rate of 43.3p per kW would drop to...
naturals
N
