Discus
This has me stumped! Please read on for a brain teaser.
I have a 2003 Expert HDI with air-con which I bought six years ago. The heater fan has always run - even in the off position. The slider worked to increase the speed & the air-con works fine.
Last week I had a new windscreen fitted. Afterwards, the fan was very noisy - making a 'thrumming' noise as through there was a piece of cardboard hitting the blades. I assumed something dropped into the fan & was stuck.
At the weekend, I had to do an 8 hour journey. After 30 mins I had to stop, as the noise was giving me a headache. I looked at the handbook & with the engine running, tried taking out all of the fuses related to the fan in the dashboard fuse board. None stopped the fan running.
I then tried taking out every fuse in turn, with the same result. There was no info on relays, so I tried removing each of 3, no change.
Getting desperate, I went under the bonnet & removed the 20A fuse. RESULT! The thrumming noise stopped, the fan worked fine, although perhaps a little slow. It now switches off with the slider in the off position, and the air-con works! Everything else is working fine.
I have a vague idea that somehow the relay has bypassed & maybe the wiring will be overloaded, but I have done 600 miles with no blown fuses or fire!
Any ideas gratefully received!
