Instyle LED Lighting Specialists UK
Advertisement - Content continues below
Discuss Well, am I glad today's over. in the Electrical Forum area at ElectriciansForums.net
GBDamo
Supporter
Electrics is a simple game complicated by fools.
Simple enough job, enclosed contactor in outhouse, indoor switch key switch.
Scoped it out a couple of weeks ago, cables runs, parts the lot, jobs a doddle.
Quoted at 4 hour plus £200 parts.
Ran in the flex internally in YT2, drilled through the 600mm outer wall, then a bit of unistrut to span the gap, bit of copex for the exterior section, drilled through the 500mm outhouse wall... clip, clip, clip, left plenty to terminate.
Goes back inside terminates switch.
All going well....
Until...
THEM; Can we have an indicator light on it?
ME; Really?
THEM; Yes, it's in the spec.
ME; you have a spec?
THEM; Yes we do them all the same.
ME; did you not think to show me this beforehand? I'm going outside for five minutes.
No effing Neutral.
Rip it all out, run in a four core, only now can I get the cable through the exterior wall....
Use old three core as draw string - fail
Fishing rods - fail
Redrilled hole - fail
Now the rubble fill keeps falling down..
An hour and a half of drill and vacuum and eventually I'm through.
Interior stud wall, now a rouge cable has dropped down and is blocking my hole, zones? A 10 second job adds another thirty minutes.
All told the four hour doddle was a ten and a half hour nightmare.
All working and tested with 15 minutes to spare before they closed.
Threw more than a few effs into this job, not what you need on a friday.
GBDamo
Supporter
  • #5
Life would've been so much easier if you'd just remembered to say 'No' instead of 'Really'!
Simpler yes but significantly poorer.
They paid for the rework as they hadn't given me the spec.
But yours right ultimately.
Ha! It's always when the job is going too well that these things happen!
Everything turning out as expected, all gear available, nothing forgotten or missing, most of the way through the job and you're already secretly congratulating yourself on a job well done...thoughts turn to the possibility of an early finish...and BOOM! It's all out the window in a heartbeat!
GBDamo
Supporter
  • #9
Exactly this.
Wilko
In my case I was supposed to be adding a security light as per verbal instruction. But on site "we don't want another light now, we just want a sensor added further down, that'll be easier right?" Oops, now need 3+E between the 2 locations. And having no pir unit in my back pocket I went home early, so not all bad :) .
GBDamo
Supporter
  • #11
Jammy git
Electrical2Go - Online Electrical Supplier
Reply to Well, am I glad today's over. in the Electrical Forum area at ElectriciansForums.net
Top Bottom
