Discuss What back box should I use in the UK Electrical Forum area at ElectriciansForums.net
if the holes line up use a conduit box or a round dry lining box.
what's it going to be mounted on? wall, ceiling, brick,dry line?
Sorry posted that before I seen your last post..
I would just drill and screw the the fittings to the wall, leaving enough room behind for connections
In this case I would simply chop a small hole into the brick to shove the connector block into and amount the light directly over the hole...
Looks like the only thing I can do but it's not good practice is it
you could fit a flush architrave box vertical to house the connections, then drill and plug fixings each side to mount the fitting.
Reply to What back box should I use in the UK Electrical Forum area at ElectriciansForums.net
Has anyone used or fitted this type of back box ? It is a 1G & 2G
https://www.gprokit.com/lever-junction-box/lighting-control-box-flexi-box Anyone used these before? Essentially a Klik box without the added cost...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
I find myself in the position of having to fit a few back boxes in to plasterboard. In the past for the odd one I just used a hand plasterboard...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
