Discuss What building can I put 3-333kva, single phase distribution transformer? in the UK Electrical Forum area at ElectriciansForums.net
Might be worth giving a bit more information if you want a decent reply.
Hi,a building which affords the required level of security,protection from flora and forna,access and position,to supply known or likely circuits,built with thought to any future maintenance,and using materials which are both expected to last the life of the equipment,and locally sourced.
Easy :)
Reply to What building can I put 3-333kva, single phase distribution transformer? in the UK Electrical Forum area at ElectriciansForums.net
When there exists a single-phase transfer switch within a 3-phase distribution system, is it necessary for both feeds to the transfer switch to be...
Hi I have UPS 50KVA and the inverter output AC voltage is feeding a distribution panel 120/208 V 4 wires when I check UPS display it shows me...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
We have to install 3 x 240mm singles and 1 neutral to a panel in a LV room.the ducts aren't large enought.What happens if the singles are split...
I have been asked if I can wire a motor for a car lifter in a domestic garage, however the motor is 3 phase and only single phase is available in...
