Discuss what cables to install?? in the Home Media Centre Forum area at ElectriciansForums.net
zone77
hi guys,
i am purchasing a flat screen plasma to install on the wall. can anyone tell me what cables i need to chase into wall for:
  • blueray dvd home cinema surround sound
  • HD sky plus box
  • playstation 3
any advice on the installation would be much appreciated. thanks
Your sky will clearly be HDMI, PS3 are HDMI and i assume your blue ray player is so they all need HDMI cables. Make sure you allow sufficient length as i have seen peope order leads which are far too short and end up unable to connect them at one end. You will also need a power supply for the telly - obvious i know but better to mention it in case. For best sound quality, use an optical cable between your Sky HD and the sound system, not sure if the PS 3 will work through it that way though - you can use an optical cable from the tv output to the sounds system but that is slightly less quality! Hope this helps a little!
i use the version 1.4 HDMI leads from http://www.cables-leads.co.uk/ - they have never let me down on price or quality. I am sure the offer advice on what you need for your system too!
check your PS3 and DVD, as long as its HDMI on there you wont need it. You can always put one in for an option later on (my xbox is the old one and uses scart, but the new ones dont) To be fair, most things you get now are HDMI. Depending on how far you want to go, you could add some Cat 5 or cat 6 from your router too, as some tvs have ethernet ports - all depends on how far you want to go or what equipment you have
Id tend to try n fit trunking of some description to enable replacement,upgrading as the advances in TV and teck moves a such a fast pace right now that futureproofing is almost impossible
Reply to what cables to install?? in the Home Media Centre Forum area at ElectriciansForums.net
I have a client who wants an EV charger installed, charger TBC, but about 7KW, installed about 20m away from this installation. I've not done one...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
I'm currently refurbishing a room and in the process adding some internal wall insulation. The wall has been stripped and my electrician has...
