Discuss what cert is required in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
My thinking was if a CU change it could be covered on that...... thats all. Trying to save the planet and use less paper!
Are you a tree hugging eco warrior ?
;-D
Agreed though , i wouldnt write seperate cert for isolator if swopping CU
not a cu change, old cu rewirable has no means of isolating (cu change would be the right thing) but a lad has just asked me about this
im thinking meiwc
or a eic with just the relevant bits
Reply to what cert is required in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
