Discuss What code for Eicr in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
g-davies
If the bathroom lighting circuit is not protected by an rcd/rcbo,and the supplementary bonding is not evident,what code would be adviseable on the EICR.Your thoughts please?
C2 , and you can take that to the bank.
It's either there or it's not don't get what you mean by not evident. You need to get the meter out and prove if its bonded or not. If not bonded then code 2 as above.
always assuming that the bathroom pipework is actually extraneous.
Well, you've outlined a large number of houses in the UK to an unsatisfactory then.
If its an central high level fitting, enclosed type - then a C3 for me.
Tin hat on.
Reply to What code for Eicr in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys Completed an EICR yesterday. One of the Sockets Radials had no CPC so R1+R2 plus Zs could not be not be completed. Does anyone know the...
Just wanted to get some thoughts from other electricians who regularly do EICRS, does anyone else code a fan isolater with no 3A fuse protection?
Private tenant since 2011. First ever eicr February 23 informed via text it failed by text from electric secretary arranging appointment for...
Hi everybody, I've been asked to do a EICR in a commercial property, So i popped in to have a look on my way home quickly and found the lighting...
Good Afternoon All Currently doing an EICR on common parts of a big site with multiple blocks. All blocks have outside garden spike lighting in...
