Discuss What code should be given for no RCD on lighting circuit of a CU in a house about 15 yrs old in the UK Electrical Forum area at ElectriciansForums.net
Probably C3
Also see Best Practice guide #4 (though web browser complaining today as their certificate expired on Fri, 01 Oct 2021 23:59:59 GMT):
I think electrical safety first says C3, but NAPIT code breakers is C2 (Presuming cable buried less than 50mm in wall). Is there any outdoor lights that are metal? That might make a difference if say a metal outside light next to a washing line poked in the ground.
Some electricians would C2 it and defend themselves reasonably, but then some C2 a plastic board, its your professional opinion so as long as you can justify it, even the experts are divided. Personally in most circumstances I would give it a C3 but would not look down on anyone that C2'd lighting without RCD protection.
Reply to What code should be given for no RCD on lighting circuit of a CU in a house about 15 yrs old in the UK Electrical Forum area at ElectriciansForums.net
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
I've tried to research and form a plan without asking on here, but I'm just going around in circles. Just completed an EICR. The wiring ranges...
